1992 Geo Prizm Headlights do not come on
TPALLISON
  • 1992 GEO PRIZM
  • 4 CYL
  • FWD
  • 230,000 MILES
The high and low beams will not come on but the high beams do work in the flash posititon. I checked the fuses, checked the fusible link next to the battery, and I replaced the headlight relay switch. I thought maybe the selector switch on the column was bad. However, when I turn the headlight switch to the on position the headlight relay switch makes a small click just like it clicks when I pull the switch to the flash position and the lights come on. This makes me think that the headlight switch on the column is O.K. What next?
Do you
have the same problem?
Thursday, December 6th, 2007 AT 6:39 PM
RCKWESLEY
Did you check the dimmer switch for power
Friday, December 7th, 2007 AT 8:32 AM
Recommended Guides
