Timing marks
WILSON ALVAREZ
  • 1997 GEO METRO
  • 13,000 MILES
I need the diagram for the timing marks on a 1997 geo metro.
Saturday, October 27th, 2012 AT 3:18 AM
IMPALASS
  • 3,112 POSTS
Here are the engine camshaft timing marks.
https://www.2carpros.com/diagrams/geo/metro/1997
Cheers
Saturday, November 3rd, 2012 AT 6:12 AM
JEFF HOLT
  • 1996 GEO METRO
  • 4 CYL
  • FWD
  • 134,000 MILES
I am trying to set the timing on a 1.3 liter and the manual that I have doesn't show the timing marks or a picture
Tuesday, September 3rd, 2019 AT 2:11 PM (Merged)
IGNITION TIMING
IGNITION TIMING SPECIFICATIONS (Degrees BTDC @ RPM) (1)
Application Auto. Trans. 4-6 BTDC @ 800-900
(1)If specification differs from emission label, use specification listed on emission label.
(2)With jumper wire installed between 6-pin duty check DLC terminals "D" and "E", located behind left strut
JOANNCWILFO2
  • 1996 GEO METRO
1996 Geo Metro
NEED TO KNOW TIMING MARKS DO U HAVE A DIAGRAM
https://www.2carpros.com/forum/automotive_pictures/12900_timing_marks_10.jpg
TIMOMO
  • 1997 GEO METRO
  • FWD
  • MANUAL
  • 120,000 MILES
Timing gear and crank initial timing position
KHLOW2008
  • 41,815 POSTS
Hi timomo,
The site has just been upgraded and everything is different so I am still feeling my way around. I can't find any way of posting diagrams so if you would let me have your email, I would send the replacement procedures to you.
MARIE JOHNSON
  • 1994 GEO METRO
1994 Geo Metro
I have a 1994 Geo Metro 1.0 This is a 3 cylinder engine. This car broke a timing belt before I got it and someone else has had the cam gear out. We are trying to time the car and would like to know the correct position of the cam gear. There are 2 timing marks 60A and 80A. Wich one is the correct one to use? The car runs but lacks power.
BLUELIGHTNIN6
  • 16,542 POSTS
Check that the timing mark on the camshaft timing pulley is aligned with the V mark on the cylinder head cover. If not align the 2 marks by turning the camshaft by be careful not to turn it more than the allowable range.
Check that the punch mark on the crankshaft timing belt pulley is aligned with the arrow mark on the oil pump case. If not align the 2 marks by turning the camshaft by be careful not to turn it more than the allowable range.
With the 4 marks aligned, install the timing belt on the 2 pulleys in such a way that the arrow marks on the belt (if so equipped) coincide with the rotating direction of the crankshaft. In this state the No. 1 piston is at top dead center of its compression stroke.
https://www.2carpros.com/forum/automotive_pictures/261618_1_137.jpg
JACK W
  • 5 POSTS
  • 1993 GEO METRO
Engine Mechanical problem
1993 Geo Metro Front Wheel Drive 109000 miles
YOU sent me a schematic of the timing marks for my geo metro 1.0 3cyl and I did the timeing and all that but it still dose nothing but crank over and over but wont start still. It's getting fuel and spark but still wont start can you please give me some advice as what to try to get it to start?
BMRFIXIT
  • 19,053 POSTS
You are bouncing all over the place and I couldn't keep up with you
lets keep it in one post just hit ( reply to question )
recheck the timing marks I had sent you the diagram
do a compression test
check the if you have the spark plug clean and in the correct order
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_54.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_32.jpg
JACK W
  • 5 POSTS
THANK YOU FOR THE FIERING ORDER FOR MY METRO NOW DOSE THE CRANK SHAFT PULLY HAVE LEFT HAND THREADS CAUSE I CAN'T GET IT TO BREAK LOSE FOR ME.
BMRFIXIT
  • 19,053 POSTS
Left turn
Its very tight
use of air tools would be wise
impact tool
DSGNWOOD
  • 1992 GEO METRO
1992 Geo Metro Front Wheel Drive Automatic
how do the timing gears/pulleys align? I think the crankshaft pulley timing mark is on top dead center, but i'm not sure of the position of the camshaft mark. The engine is a 1.0 ltr suzuki.
Put the engine no.1 piston on its compresssion/TDC and line the sprockets -see below
https://www.2carpros.com/forum/automotive_pictures/12900_timing_geo_1.jpg
67BADMOPAR
  • 1987 GEO METRO
1987 Geo Metro 150000 miles
I am trying to ficure out the timing mark alignment for a 1.0 liter three cylinder. I have a manual but it is just telling me to align them. Do I align them crank gear up cam gear down? Or both up? I am lost
Put the engine no.1 piston on its compression stroke then align the sprockets as you see below
https://www.2carpros.com/forum/automotive_pictures/12900_alignment_cam_and_crank_1.jpg
67BADMOPAR
As in tdc?
Correct
JOHNDOUGWILL
  • 1994 GEO METRO
Engine Performance problem
1994 Geo Metro
lining up notches according to book and vehicle won't crank
Tuesday, September 3rd, 2019 AT 2:12 PM (Merged)
