Fuel shut off switch
ANONYMOUS
  • 2004 DODGE DURANGO
Where's the emergency fuel shut off switch for just in case you've gotten in a crash I went a little off reading and once I got on the road it acted as if I was running out of gas but I had a half a tank and then the car came to a stop and died and would not start after that like its wasn't getting has at all changed the fuel pump fine checked the fuel filter, injectors ECT all working please help :(
Friday, November 30th, 2012 AT 2:57 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
There is only a fuel pump relay for your car Ford is the only car company that has an inertia switch. Here is a guide and some diagrams (below) so you can test the fleup pump relay.
Cheers, Ken
Saturday, October 21st, 2017 AT 3:56 PM
  • 52,797 POSTS
Hello, this car does not have one. Only fords do. Use 2CarPros anytime, we are here to help. Please tell a friend.
Wednesday, January 30th, 2019 AT 1:38 PM (Merged)
