Fuel tank pressure sensor
THE AUTO FIX
  • 2006 CADILLAC CTS
  • 2.8L
  • V6
  • 97,231 MILES
Location of sensor. Have a p0451 code. Replaced the gas cap. Purchased sensor. Not sure if it’s on top of fuel tank or canister. Need your help.
Thanks
Do you
have the same problem?
Thursday, June 30th, 2022 AT 11:38 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,544 POSTS
It looks like the fuel tank pressure sensor is on the charcoal canister in the rear of the vehicle. Here is the location of the sensor and how to change it out in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Friday, July 1st, 2022 AT 9:30 AM
THE AUTO FIX
  • 6 POSTS
Thank you for your help pertaining to this matter. You guys are a God sent. Will let you know my results.
Friday, July 1st, 2022 AT 11:26 AM
THE AUTO FIX
  • 6 POSTS
  • 2006 CADILLAC CTS
  • 2.8L
  • V6
  • 97,000 MILES
Would all engine sizes sensor location be on the canister design the wheel wells?
Thank you
Tuesday, July 12th, 2022 AT 6:49 PM (Merged)
SQM
  • 6,383 POSTS
The fuel tank pressure sensor is located on the EVAP canister.
It is the same location regardless of the engine size (2.8L or 3.6L).
I have attached diagrams below for your reference.
Let me know of any questions.
THE AUTO FIX
  • 6 POSTS
  • 2006 CADILLAC CTS
  • 2.8L
  • V6
  • 92,359 MILES
You have commutated the sensors part of the charcoal canister. Not sure of the exact location of the canister. Would much appreciate your help with this matter.
