Can be a bad pump? I need to replace it again?
IPASAL083
  • 2006 NISSAN SENTRA
Hi!
I replaced my fuel pump. After I replaced it the check engine light came on the codes that it showed were PO181 and PO183. So, I called up the Nissan dealership and talked to the repair guys there. They said it can only be a bad pump and I should replace it again. So I did. As soon as, I replaced the pump the same codes keep coming up. So I don't think it's the pump. So my question is. Is there something else I need to replace when replacing the fuel pump?
Thank you!
Thursday, September 23rd, 2010 AT 11:31 AM
DOCFIXIT
  • 18,828 POSTS
Was pump an O.E.M or aftermarket? if aftermarket did it come as complete assembly? with FTT ? see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_620.jpg
181 and 183 faulty fuel temp and fuel level sensors
Thursday, September 23rd, 2010 AT 2:06 PM
IPASAL083
I believe it's an aftermarket pump. I ordered it from NAPA. The only thing that I got was the pump by itself nothing else came along with.
Sunday, September 26th, 2010 AT 12:38 AM
DOCFIXIT
  • 18,828 POSTS
Codes will stay till FTT is repaired or replaced
Sunday, September 26th, 2010 AT 2:24 PM
LISAGILPIN
  • 7 POSTS
  • 2004 NISSAN SENTRA
  • 100,000 MILES
How to remove the fuel strainer off of fuel pump?
Saturday, August 8th, 2020 AT 12:43 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Remove fuel pump from tank. Can be accessed through a cover plate under rear seat. Why?
STUMPEDBYCAR
  • 2001 NISSAN SENTRA
  • 4 CYL
  • 216,000 MILES
I have tried everything. The dealer is stumped, other mechanics are stumped and I have ruled out that the gas pump is emitting some kind of electrical interference (I think). When I am at the gas pump and after I have finished pumping the gas, put the cap back on, the car won't start without being given alittle bit of gas. This is very unusual and not the way the car is supposed to start. I can then drive away 10 feet, shut off the car and then it will start fine. It starts fine anywhere else at anytime of the day no matter how long it has been sitting but it won't start after pumping the gas at the gas station. I have tried filling at different intervals (empty to full, half empty to full, etc.). It still won't start right away. I have tried sitting in a parking lot with the gas tank open and it will still start. I have tried just sitting by the gas pump, turn off the car, wait a few minutes and the car will still start. I have tried turning the key to "on" for a few seconds and then off again and then to the "on" position for a few seconds and then off again and it still won't start while at the gas pump. The dealership had run the error codes and replaced the spark plugs and a sensor and a filter but it still didn't start at the gas pump. Could it be something in the gas tank that is loose that is being disrupted by the gas being pumped in? What is left to look at?
Saturday, August 8th, 2020 AT 12:44 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
You're problem pretty much has to be related to the pump itself. My guess might be that the pump is reacting to sudden temp change in the fuel but you're going to have to pull the tank down to investigate further.
FIXERUPPER2013
  • 100,000 MILES
My car started giving me problems after I took it on a long road trip. It started overheating. At first they told me it needed a radiator flush, but I couldn't afford it so I kept driving it. After a few weeks, it wouldn't start, so a relative who is a mechanic told me it was the gas pump that needed to be replaced. I had a friend take out the old gas pump, so now the car doesn't have a gas pump at all. I had it towed to Pep Boys, and they started asking me for parts not even the dealership carried. Now I'm stuck with the car without a gas pump and have no idea how to get it running again. Is it possible to order a used gas pump online or is it only from the dealership that I can order it?
CARADIODOC
  • 33,741 POSTS
Where's the old assembly?
Fuel pumps are part of an assembly and are a commonly-replaced item. All auto parts stores will have them or can order them. The question is whether it will come installed in a new housing already, or if it is just the pump and motor that has to be installed into the original housing. Often a new pump is available both ways.
There are other parts that may need to be removed, but they are not replaced. Since those are not commonly replaced, they will usually not be available at auto parts stores. Those will be dealer-only items, and even they may have to special-order them.
You can also find missing parts at a salvage yard, but if selling you a certain part renders the rest of the fuel tank unusable, you can expect to have to buy the entire tank. Often they will have a tank that was damaged in a crash so it's already unusable. They'll sell you parts from those very inexpensively.
The dealership can order any part that went into building the car, as long as it's still available. Normally it's Fords that parts aren't available after just a few years. They do a very poor job of supporting their products. Your car is 12 years old. That's a fairly long time to supply replacement parts so what you need may be no longer available from the manufacturer unless the same parts were used on much newer models. That's when a trip to the salvage yard is needed.
Auto repair shops routinely deal with the salvage yards too. All they have to do is figure out the parts that are needed or missing, then call the yard with their list. It may take a day to have someone remove them from the car, but then they often deliver them right to the repair shop.
FREAKDOGSLIM
  • 2000 NISSAN SENTRA
  • 4 CYL
  • 165,000 MILES
How do you replace the fuel pump and filter?
Saturday, August 8th, 2020 AT 12:45 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi freakdogslim,
Here are the procedures.
FUEL PUMP, FUEL LEVEL SENSOR & FUEL FILTER -
https://www.2carpros.com/forum/automotive_pictures/192750_FuelPump00SentraFig02_1.jpg
Removal & Installation
1. Release fuel pressure. Remove access cover located under rear seat. Disconnect fuel hoses and electrical connector. Remove fuel pump assembly screws. Remove fuel pump assembly from fuel tank.
2. Using a screwdriver, disengage clips holding fuel pump assembly to chamber, in order shown in illustration. See Fig. 3. Disengage fuel tank temperature sensor wiring harness. Disengage clips holding fuel level sensor to chamber. Pull fuel level sensor upward.
3. Disconnect fuel pump harness connector. Disconnect hoses from fuel level sensor unit. Pull fuel level sensor unit upward and out of chamber. Disengage locking tabs holding fuel filter into chamber.
4. Pull fuel filter out of chamber. Using a screwdriver, remove fuel pump bracket. Pull fuel pump out of fuel filter. To install, reverse removal procedure. Tighten bolts to specification.
https://www.2carpros.com/forum/automotive_pictures/192750_FuelPump00SentraFig03_1.jpg
KA9VTO
  • 4 CYL
  • 64,000 MILES
I was replacing the fuel pump Assembly and I found a o-ring laying and not sure where it goes, and is there only one? Aprox 7/16ths across
BMRFIXIT
  • 19,053 POSTS
Is it a big o ring
it goes between the pump module and fuel tank
https://www.2carpros.com/forum/automotive_pictures/99387_sentra_1.jpg
KA9VTO
No its not the big one at the opening this one is about 7/16ths across
BMRFIXIT
  • 19,053 POSTS
I cannot locate any other o rings
is it a rubber o ring
I would check the quick connector if had it fallen put of it
i should have two inside of it
KA9VTO
Yes its rubber, I do not see any o-rings inside of the connector lines would both lines take one or just the one from the pump? As I stated I only found one o-ring
BMRFIXIT
  • 19,053 POSTS
I'm trying to recall how or if any small o ring is in the fuel pump module
and I cant come up with any thing else
is it possible its an extra part that some one put it in the box by mistake
RFH
  • 4 CYL
  • FWD
  • 60,000 MILES
Replaced the fuel pump. Car started ran for a few moments then stalled and will not start. Gas is getting to fuel injectors but seems to sto there? Car will not restart
BLUELIGHTNIN6
  • 16,542 POSTS
Are you certain its a fuel problem? If its getting to injectors and stops there then injectors are either clogged or not pulsing. Will need to test each injector. May want to check compression on cylinders and check spark, may not even be fuel related issue.
MELOR
  • 1998 NISSAN SENTRA
1998 Nissan Sentra 4 cyl Automatic
My car did not pass inspection because it needs fuel module control. I bought it and took it to my mechanic, but he cann't find where it should be installed. Can you help me, please?
OV
Saturday, August 8th, 2020 AT 12:46 PM (Merged)
