Fuel pump relay.
FRANKLIN SITS POOR
  • 1992 CHEVROLET TRUCK
  • 4.3L
  • V6
  • MANUAL
  • 200,000 MILES
My truck will not start until I pour gas into the tbi then stalls after a fee seconds, then repeat pouring in gas. I read all the comments and problems. I need to know where the ignition module is located. So the truck can idle and run again.
Do you
have the same problem?
Sunday, June 26th, 2016 AT 7:24 PM
CJ MEDEVAC
  • EXPERT
If it is firing up, you must be getting spark, probably rule out the ignition module!
Sounds like you are lacking fuel!
I am going with a severely stopped up fuel filter (doubts again)
When it is good and quiet, do you hear the fuel pump hum a couple of seconds when the key is turned to "ON"?
If not, check fuses and the possibility that the fuel pump has kicked the bucket.
The Medic
Sunday, June 26th, 2016 AT 7:32 PM
Recommended Guides
