Fuel Pump
RAGANCHANCE
  • 2001 GMC YUKON
  • 150,000 MILES
I have a 2001 GMC Yukon that will not run. I had the fuel pump replaced about a year ago but and it ran fine. Now the pump makes a loud niose when you turn the key on then it stops but the car will not start. I need help troubleshooting the issue. Does it sound like a bad fuel pump or could it be something else.
Do you
have the same problem?
Friday, May 10th, 2013 AT 8:57 AM
HMAC300
  • EXPERT
Scan for codes and check fuelpressure first.
Friday, May 10th, 2013 AT 9:37 AM
Recommended Guides
