Fuel pump removal
ALEX19899
  • 2000 NISSAN PATHFINDER
  • 6 CYL
  • 180,000 MILES
Hello, I'm planning to replace the fuel pump and I was looking for a detailed walkthrough on replacing it.
Do you
have the same problem?
Thursday, June 6th, 2019 AT 4:09 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial to get you started on how to replace the in-tank fuel pump:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
I've attached a series of step-by-step pictures below.Hope this helps and thanks for using 2CarPros.
Danny-
Thursday, June 6th, 2019 AT 4:34 PM
ALEX19899
  • 171 POSTS
How to I attach the fuel pump to the plastic bracket in the bottom of the fuel tank?
Wednesday, June 19th, 2019 AT 3:30 PM
ALEX19899
  • 171 POSTS
  • 3.2L
  • V6
  • 150,000 MILES
So, I replaced the fuel pump and I lost six screws for the fuel pump cover. So I drove it for about fifteen minutes and now it wont start, just tries to turn over but nothing. Since I only had three of six screws installed would that cause air to go into the fuel lines? And the rubber gasket that's right under the fuel pump isn't seated right.
Friday, June 21st, 2019 AT 11:23 AM (Merged)
  • 108,014 POSTS
Welcome to 2CarPros.
Air has to get into the tank to allow fuel to be removed, so I don't think that is the issue and unless the pump is lifted above the fuel level, air in the lines shouldn't be a factor. I attached a picture and circled the part I believe you are referring to (see Pic 3). If that is correct, my biggest concern would be that fuel could leak from the o-ring where it mounts. However, that wouldn't cause it not to work.
Have you confirmed that all connections (both electrical and fuel lines) are secure? Are you smelling any fuel indicating a possible leak? Can you hear the pump turn on for a couple seconds when you first turn the key to the on position?
If you don't hear the pump and everything is connected properly, check under the hood in the fuse / relay box 2 (see pic 1) if there is an issue with the fuel pump relay or fuse (see Pic 2). If there are other relays with the same part number, switch them to see if that makes a difference.
Here are a few links you may find helpful when checking the relay and fuses:
_____________________________________________________________
Let me know if any of this helps or if you have other questions.
ALEX19899
  • 171 POSTS
I tried to hear the pump turn on, but I do not hear anything.
ALEX19899
  • 171 POSTS
Here is the picture of the relay fuse in the blue:
ALEX19899
  • 171 POSTS
Will a test light work to check the relay?
Friday, June 21st, 2019 AT 11:55 AM
ALEX19899
  • 171 POSTS
I replaced the fuel pump relay and still no power.
Friday, June 21st, 2019 AT 11:30 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
I don't see the image?
Tuesday, June 25th, 2019 AT 12:05 PM
