Fuel problems
BOB9392
  • 1992 CHEVROLET CORSICA
  • 95,000 MILES
Hello
I have a 92 corsica that started sputtering acting like it was running out gas then it wouldn't start If it did it ran for a few seconds then quit and wouldn't start. I have changed fuel pump, fuel filter, fuel pump relay and the crank sensor. Still the same problem. If I spray fuel in to the throttle body I can keep it running. I can't afford to keep putting parts in it or take it to the shop. Any ideas what it might be wrong I'm stumped.
Do you
have the same problem?
Monday, May 20th, 2013 AT 9:15 AM
HMAC300
  • EXPERT
Check your fuel pressure it should be 41-47 psi.
Monday, May 20th, 2013 AT 9:31 AM
Recommended Guides
