Also fuel sending unit not working. Which wire is which? Such as ground/resistor/power. I will check again the 2 power at the COR. Stand by my friend.
Monday, September 7th, 2020 AT 3:28 PM
EXPERT
The blue/black wire as in the diagram I attached.
SPONSORED LINKS
Monday, September 7th, 2020 AT 3:30 PM
PACIFICISLANDER
MEMBER
The STA has power at all time and the fuel pump has for 2 seconds then gone.
Image (Click to enlarge)
Monday, September 7th, 2020 AT 8:09 PM
EXPERT
Okay, if you reinstall the relay and turn the key on, can you feel the relay click?
Tuesday, September 8th, 2020 AT 3:40 AM
PACIFICISLANDER
MEMBER
No.
SPONSORED LINKS
Tuesday, September 8th, 2020 AT 8:30 PM
EXPERT
If the relay control side has power to the relay, but does not energize, then it is either the relay or the ground for the control side which is at the left kick panel.
Images (Click to enlarge)
Wednesday, September 9th, 2020 AT 4:32 AM
PACIFICISLANDER
MEMBER
On the COR which pin is the control side? The ground there's 5 pins.
Wednesday, September 9th, 2020 AT 5:07 AM
EXPERT
The black wire is the wire from the ECM. The white/black wire is the ground for the control side. That is the current issue we are trying to work with since the relay will not energize.
Wednesday, September 9th, 2020 AT 5:10 AM
PACIFICISLANDER
MEMBER
The black wire is coming from the PCM and then goes through the COR and then to white/black then to G200, correct?
Wednesday, September 9th, 2020 AT 3:04 PM
EXPERT
Yes, G200 is a ground.
Wednesday, September 9th, 2020 AT 3:10 PM
PACIFICISLANDER
MEMBER
Don't know what to do without you, you been so helpful which pins on the COR. So I can trace the wire and do a continuity test from the black wire to the PCM and black/white to ground. There's 3 wires on the ground G-200 if it checks out we dealing with the computer.
Wednesday, September 9th, 2020 AT 4:46 PM
EXPERT
Correct.
Glad to help.
SPONSORED LINKS
Wednesday, September 9th, 2020 AT 4:57 PM
PACIFICISLANDER
MEMBER
Where's is the control side of the relay COR?
Friday, September 11th, 2020 AT 2:03 PM
EXPERT
It is inside the relay.
The black wire comes from the ECM and the white/black is the ground at g200.
Friday, September 11th, 2020 AT 2:09 PM
PACIFICISLANDER
MEMBER
Black wire does it have power at all time when key is on and label STA?
Saturday, September 12th, 2020 AT 12:59 AM
EXPERT
As we discussed before, that is power from the ECM. With the key on, it should have power for 2 seconds.
Then when cranking, it should have power all the time.
Saturday, September 12th, 2020 AT 5:14 AM
PACIFICISLANDER
MEMBER
Which white and black wire is the ground that goes to G200 is it the Fc or the E1?
Saturday, September 12th, 2020 AT 9:49 PM
EXPERT
E1 is the ground wire.
Sunday, September 13th, 2020 AT 4:25 AM
PACIFICISLANDER
MEMBER
I'm getting confuse here. The black/white wire goes to G200 and which black wire coming from the PCM to complete the control side of the relay. I need to confirm this that the PCM is defective so I get one.
Sunday, September 13th, 2020 AT 2:04 PM
EXPERT
We went over this many times.
The black wire comes from the ECM to power the control side of the relay. It has power for 2 seconds and turns off with the key on.
