I attached the wiring for this. Can you go to the fuel pump relay and we can do some testing?
I attached the testing below and some pictures.
CIRCUIT OPENING RELAY INSPECTION
1. REMOVE CENTER CLUSTER FINISH LOWER PANEL
2. REMOVE FINISH LOWER CENTER PANEL
3. REMOVE CIRCUIT OPENING RELAY
4. REINSTALL EFI MAIN RELAY
A. Inspect relay continuity
Using an ohmmeter, check that there is continuity between terminals STA and E1.
If there is no continuity, replace the relay.
Check that there is continuity between terminals +B and FC.
Check that there is no continuity between terminals +B and FP.
If there is continuity, replace the relay.
B. Inspect relay operation
Apply battery voltage across terminals STA and E1.
Using an ohmmeter, check that there is continuity between terminals +B and FP.
Apply battery voltage across terminals +B and FC.
Check that there is continuity between terminals +B and FP.
5. REINSTALL CIRCUIT OPENING RELAY
6. REINSTALL FINISH LOWER CENTER PANEL
7. INSTALL CENTER CLUSTER FINISH LOWER PANEL
Images (Click to enlarge)
Thursday, September 3rd, 2020 AT 3:59 AM
