REPAIR GUIDES
BECOME A MEMBER
Sign up with Facebook
OR
I agree to the
user agreement
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
Home
Chevrolet
Silverado
Engine
Symptoms
Stall at Idle
Engine will not stay running
ISAACMTZ
MEMBER
1999 CHEVROLET SILVERADO
111,000 MILES
Truck will start but shut off 20 minutes later and not start again for a long time.
Do you
have the same problem?
Tuesday, September 29th, 2020 AT 6:35 AM
EXPERT
Good morning,
When it does not start, can you check the fuel pressure to be sure the pump is working?
Can you check for spark to the plugs as well?
Images (Click to enlarge)
SPONSORED LINKS
Tuesday, September 29th, 2020 AT 6:48 AM
ISAACMTZ
MEMBER
It won't start after it gets warm, you can start it everyday for about 20 minutes then it will shut off and not start again. The sparks are good.
Tuesday, September 29th, 2020 AT 8:51 AM
EXPERT
Okay, got it.
You need to test the fuel pressure when it will not start.
Tuesday, September 29th, 2020 AT 8:57 AM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
Engine Will Not Stay Running?
C-1500 After Engine Warms Up Starts To Run Rough And Shuts Off At Low Rpm. Get Code 54 And Have Tried All The Easy Possible Fixes.
Asked by
chas662
6 IMAGES
1994
CHEVROLET SILVERADO
GUIDE
Stalls After Dead or New Battery
Easy step by step guide on how to repair an automotive engine that is stalling after a new battery has been installed, this information pertains to most vehicles.
Truck Stalls When Put In Gear?
Truck Stalls When I Put It In Gear. I Have Changed The Tps Sensor, Injectors, Fuel Regulator, Plugs, Wires, Cap, Rotor, Coil, Runs/...
Asked by
wa
1990
CHEVROLET SILVERADO
Engine Stalls At Idle?
Hi, My 1994 Chevy 2500 V8 K Vin 5.7 Liter Stalls At Cold Idle And While Driving, But Esp When I First Crank It Up Cold. I Had This Prob A...
Asked by
dsplace2007
1 IMAGE
1994
CHEVROLET SILVERADO
Engine Backfires And When Put In Gear Dies
Engine Died After Running On Low Tranny Fluid And Would Not Start Again Until I Replaced Ingnition Coil And Cap, Rotor, Spark Plugs, And...
Asked by
mborland
1 ANSWER
CHEVROLET SILVERADO
2000 Silverado Will Not Idle
2000 Silverado 2500 4x4 6.2l 111,300 Mi Truck Started To Act Up Recently. Engine Will Not Idle. Difficulty Starting. Need To Try To...
Asked by
sundogusa
2000
CHEVROLET SILVERADO
VIEW MORE
SPONSORED LINKS
Stalls at Idle
Serpentine Belt Replacement Mercedes Benz ML
Coolant Leak Symptoms
Help us make this site better
Online car repair manuals
