Front brakes locking up
NOAHDON
  • 1996 TOYOTA COROLLA
  • 221,445 MILES
I have replaced everything(brake booster, master cylinder, calipers, back drums) and the front brakes keeps locking up. Also there are no leaks in the lines. If it's a cold day I may get a quarter mile before the brakes lock. On a warm day they will lock immediately. Why are my brakes locking up?
Do you
have the same problem?
Wednesday, May 15th, 2013 AT 7:16 PM
CJ MEDEVAC
  • EXPERT
. MAYBE NOT EVERYTHING!
A TWO GOOD GUESSES MIGHT BE THE THE CALIPERS OR THE BRAKE HOSES
MY MONEY IS ON THE HOSE(S) !
.I DON'T KNOW IF IT'S ONE OR BOTH. SOMETIMES A LITTLE "WAIT" AND THEY/ IT UNLOCKS ON THEIR OWN?
LETS DO SOME TESTING
GET 'EM TO LOCK UP
HAVE A WRENCH HANDY TO OPEN A BLEEDER ON ONE OF THE CALIPERS
BREAK IT OPEN. DO THE BRAKES RELEASE? (THEN CLOSE IT)
NORMALLY I SEE THIS ON ONE SIDE OR THE OTHER. SO, IF IT DID NOT RELEASE TRY THE OTHER SIDE.
THIS MIGHT BE A BAD HOSE GOING TO ONE OF THE CALIPERS. INTERNALLY, THE HOSE GETS MESSED UP AND DOES WHAT I CALL "CHECK VALVING" (ACTS LIKE A CHECK VALVE) IT WILL ALLOW FLUID TO PUSH THRU. THEN IT "CHECKS" AND WON'T LET IT "BACK OUT"
MY THOUGHT ON THIS ARE. THESE PUPPIES ARE PROBABLY THE SAME AGE, JUST FOR PREVENTATIVE MAINTENANCE SAKE, I'D REPLACE BOTH
NOT KNOWING YOUR VEHICLE WELL. THIS ANSWER IS SORTA GENERIC AND THIS PROBLEM HAS HAPPENED ON MANY VEHICLES, PAST AND PRESENT.I'M MORE IN TUNE WITH OLDER VEHICLES (LIKE '80s ON BACK), MAINLY JEEPS AND FORDS
"IF" THERE IS A 3RD HOSE ON UP THE LINE SOMEWHERE, COMMON TO BOTH CALIPERS, IF IT IS BAD, IT MIGHT MAKE BOTH SIDES LOCK UP
IF WE MUST GO ON UP THE LINE SEARCHING MORE (IF THE BLEEDER TEST FAILED), YOU MIGHT HAVE TO LOOSEN THE "HOSE TO HARD LINE" CONNECTION (WORKING YOUR WAY FROM THE BRAKES TOWARD THE MASTER CYLINDER) TO FIGURE OUT WHAT RELEASES THEM
IT MAY BE THE SLIDE OR PISTON MECHANISM BINDING ON THE CALIPER ITSELF. IT MIGHT ALSO BE ABS RELATED
LETS HOPE ITS JUST A HOSE
KEEP US POSTED ON WHAT YOU FIND
THE MEDIC
Wednesday, May 15th, 2013 AT 7:59 PM
Recommended Guides
