Front brake
STEVEN HEALD II
  • 2000 GMC SIERRA
  • 270,000 MILES
I got the top bolt loose on the caliper but the bottom got rounded off. I would like to know what be the best way to get this bolt off. I am going replace it with new one. Just needed know the best and safe way to get the job done. Thanks for your advice and help.
Steven.
Do you
have the same problem?
Sunday, May 21st, 2017 AT 7:59 PM
SATURNTECH9
  • EXPERT
The best way is to get a twist socket designed to remove rounded off nuts and bolts.
Sunday, May 21st, 2017 AT 11:13 PM
STEVEN HEALD II
Okay, but the bolt is star. I use an T55 to loosen the bolt. Can I use twist socket for this type? Thanks
Monday, May 22nd, 2017 AT 11:50 AM
SATURNTECH9
  • EXPERT
I have had success using them on rounded out Allen bolts grabbing the outside of the hole of the bolt. It is going to be tough since it is going to be pretty tight. Is it the caliper slide pins or the caliper bracket that is rounded out?
Monday, May 22nd, 2017 AT 12:24 PM
Recommended Guides
