Transmission diagnostic codes
JONPKLINE
  • FORD WINDSTAR
Recently bought a 1996 Windstar with 120,000 miles. Got the check engine light and had the codes read out. Got a P1785 "Transmechanical failure 1st and 2nd gear". Car is a little sluggish when you hit the gas. Thinking that I have a bad transmission. Any expert thouhgts out there.
Do you
have the same problem?
Monday, November 27th, 2006 AT 6:26 PM
BRUCE HUNT
  • EXPERT
I might consider having the tranny fluid changed and checked for metal particulates. See if a fresh fill helps out before going nuts with a new tranny.
Monday, November 27th, 2006 AT 8:06 PM
Recommended Guides
