Engine turns slow
BRAT WITH A BRAT
  • FORD WINDSTAR
Your battery and/or alternator may be the cause of this. If your alternator isnt giving your battery inough power the engine will run partially of the battery or if your battery is bad it will make the engine turn over slow and not start because of lack of power.
also have your starter tested becase it may be going out. Good luck!
Do you
have the same problem?
Wednesday, February 22nd, 2006 AT 5:11 AM
CASPERL
Mercury tracer 1999 engine is turning slow
Tuesday, February 21st, 2006 AT 5:10 AM
BRAT WITH A BRAT
Also have your starter tested becase it may be going out. Good luck!
Recommended Guides
