2003 Ford Windstar front heat
OSORIO493
  • 2003 FORD WINDSTAR
  • 6 CYL
  • 4WD
  • 114,000 MILES
I would like to Know what could be the problem with the heat system of my car, rear heat works very well but front heat dosn't works, no warm air come out. What could be happening. Thanks for any information.
Do you
have the same problem?
Monday, March 17th, 2008 AT 11:32 AM
MASTER TECH DAN
You need to first check the hose that got to the heater core if they are both hot then you need tos see if the accuator on the blend door is ok and or if the door is broken
Monday, March 17th, 2008 AT 2:40 PM
