2000 Ford Windstar ABS light on and speedometer jumps
LA GANZA
  • 2000 FORD WINDSTAR
Brakes problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic
hi I got 2000 windstar my problem is that when I driving up to 60 mph the ABS light come on and my speedometer jumps betwen 60 - 80 mph. But if turn the van off when I start again the light go away and dont come back if driving below 50 mph just doing this after 60 mph. Thanks for any help
Do you
have the same problem?
Sunday, July 26th, 2009 AT 1:24 PM
DADDY CANE
I believ your problem is the speed sensor. What it will do if it dont work right is fluxuate your speedo and abs comes on. Does your van have traction control? Because it will screw up too. The reason is you computer won't understand how fast your going therefore cant judge for abs, traction, and speed which will cause them all to malfunction.
Hope it makes sense to you and hope it helps.
Caio from canada
Tuesday, July 28th, 2009 AT 2:40 PM
Recommended Guides
