ABS Error code C1185
TUNDRATIGER67
  • 2003 FORD WINDSTAR
Like the thousands of you, our 03 Windstar SE has developed the dreaded ABS module problem. Dealership just quoted $1300 for the part, not including labor. I've already filed a complaint the the NHSTB. Now what?
Friday, September 5th, 2008 AT 2:11 PM
MERLIN2021
  • 17,250 POSTS
Unfortunatly, you need to pay for the repairs, then if a recall is forced, you will be reimbursed by Ford.
Friday, September 5th, 2008 AT 4:05 PM
RRAY1981
  • 6 CYL
  • FWD
  • 61,500 MILES
I have been hiving the same abs and brke light issued I have the c1185 code and 10 others including a u1262 which is a communications bus fault wondering what issue could be, I recently changed my front brakes and thats when all the lights started coming on
Monday, August 12th, 2019 AT 7:32 PM (Merged)
MERLIN2021
  • 17,250 POSTS
We have a very long thread about the Windstar ABS problem, read here:
https://www.2carpros.com/forum/2003-ford-windstar-abs-c1185-trouble-code-vt49767.html?highlight=
WOKERYDJJ
  • 2000 FORD WINDSTAR
  • 6 CYL
  • 11,300 MILES
With my 2000 Ford Windstar 3.0 liter my ABS light goes on and off a lot. I had it scanned and was told that many codes where found. My wife said she felt the back brakes grab just before the light came on the other day. Any ideas?
Monday, August 12th, 2019 AT 7:33 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Ford does not want to own up to Windstar, seems the 2000-200? Seem to have ABS problems built right in, no extra charge! One suggestion is to unplug the cruise deactivator switch on the master cylinder and use a jumper wire in the connector. May or may not be helpful. Call NTHSA at 1-888-327-4236
add your voice to this concern, if enough calls are made, you may get a Ford recall out of it.
