No heat from heater
LACHON GULLEY
I turned the key back several times and nothign changed.
Tuesday, December 20th, 2016 AT 6:21 PM (Merged)
LACHON GULLEY
I tried turning the key from off to run several times. I did not get a odometer reading but the airbag light would go out about for about 5 seconds and come back on. Also I could tell if the fuse was bad in the interior fuses but I couldn't tell if the one under the hood fuse 120 was bad. I pulled out a couple of them and they all looked the same.
LACHON GULLEY
Thanks for all your help, I really appreciate it. This is a great site.
SHERRIKARPINSKI
  • 2002 FORD WINDSTAR
  • 6 CYL
  • AWD
  • 88,000 MILES
Heater problem
2002 Ford Windstar 6 cyl All Wheel Drive Automatic 88000 miles
My front heater is blowing cold air but the back heater is still blowing warm air. What happened and how do I fix it?
Tuesday, December 20th, 2016 AT 6:22 PM (Merged)
RACEFAN966
  • EXPERT
Sounds like a blend door or blend door motor. These are both available at most parts stores and as for replacing depends on how comfortable you are with doing automotive repairs. If you like I can walk you through somewhat. Here is a pic of the door and the motor.
https://www.2carpros.com/forum/automotive_pictures/249564_538244_1.jpg
https://www.2carpros.com/forum/automotive_pictures/249564_379286_2.jpg
GO2GUY
  • 1998 FORD WINDSTAR
Heater problem
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic
hi my 98 windstar the heater and aircondtioner will not turn on in the front it was working now for some reason it wont turn on but the back works fine. Please help
GO2GUY
RUSSMC
  • 2000 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 86,000 MILES
Heater problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic 86000 miles
Our heater has quit working in the front, but still partially works in the back. It is warm but not hot. The front only blows extremely cold air. The heater core is working. What are the possible causes. Thank you for your time.
2CEXPT
Check the coolant level-disconnect the heater hoses and inspect for clogging-also the heater core use the garden hose trick and reverse flush it. Might want to replace the thermostat-good investment.
Need more help don't hesitate to ask-you don't ask -you'll will never know.
THEJBOYDS
  • 1996 FORD WINDSTAR
Heater problem
1996 Ford Windstar 130000 miles
Rear heat works fine cold air blows out of top(defroster) and out of reg vents when heat is on. Was toldto flush lines. Not sure what they mean how do you flush them with air or water?Do you think this will work or might it be something else. Doesnt make any noises.
BMRFIXIT
  • EXPERT
U can do that but check the blend door actuator
its job to close door and open between the hot and cool air
MARK LUKAS
  • 2001 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 130,000 MILES
Heater problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic 130000 miles
Greetings,
My 2001 Windstar just started this thing where as long as you have your foot on the gas driving the heater works great, come to a red light, and bam instantly blows cold air. Start driving again, gets hot again. Put it in park, goes cold instantly. I know with the old muscle cars I build you'd just change the thermostat and it's fixed, does the same hold true with these newer vehicles? Or is there something else wrong? Thanks for your help.
Tuesday, December 20th, 2016 AT 6:25 PM (Merged)
DAVE H
BASIC HEATER SYSTEM TROUBLE SHOOTING CHART
Insufficient, Erratic, or No Heat
POSSIBLE CAUSE
. Low Coolant Level
. Incorrect thermostat.
. Restricted coolant flow through core.
. Heater hoses plugged.
. Misadjusted control cable.
. Sticking heater control valve.
. Vacuum hose leaking.
. Vacuum hose blocked.
. Vacuum motors inoperative.
. Blocked air inlet.
. Inoperative heater blower motor.
. Oil residue on heater core fins.
. Dirt on heater core fins
ANDYVS
Did you find out the answer? I'm thinking vacuum but I know the hot/cold control is electric. Possibly a vacuum signal controling that though.
I need to fix it soon!
Thanks
JENN_1982
  • 2003 FORD WINDSTAR
Heater problem
2003 Ford Windstar Automatic 108231 miles
You see My back heater works but my front heater does not work and the wierd thing is my Air con works up front and not in back. What is it and how can I fix it. It blows it's like only heat comes out in the back one and cold air in front. Help me
Tuesday, December 20th, 2016 AT 6:26 PM (Merged)
BMRFIXIT
  • EXPERT
Let try and work on the heat 1st
if you open the hood and locate heater hoses by the firewall
check if both hot
if both hot suspect and check blend door and actuator
if one hot and one warm or cold
heater core need to flushed
you can access the self diagnose and check for codes
check hoses 1st and let me know
JENN_1982
Where would the fire wall be and how do I get too it and talk to me like I know nothing about cars. Oh yea I don;t LOL
BMRFIXIT
  • EXPERT
Firewall is the wall between inside of the car and engine compartment
have to open hood to check it
JENN_1982
What do the hoses look like?/ Do they say what they are are they medel or rubber?
BMRFIXIT
  • EXPERT
Small round rubber hoses I will try to find some pictures for you
if any available
