No heat from heater
2CARPROS MIKE
  • ADMIN
It's like they started with the heater box and built the car around it. :) Here is where it is located:
Tuesday, December 20th, 2016 AT 6:09 PM (Merged)
JOEUNGERICHT
Oh that looks like too much fun right now. LOL Spring project that is going to be. Thank you, everyone for all of your help.
Thanks - Joe
2CARPROS MIKE
  • ADMIN
You are welcome, if you run into any problems we will be glad to help.
JCFAMILY6
  • 2002 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 106,000 MILES
Heater problem
2002 Ford Windstar 6 cyl Front Wheel Drive Automatic 106000 miles
My van has stopped heating, while the a/c works. A "thump" developed as well when this happened. My kids call it the the vans heartbeat because literally it thumps like a heartbeat. When the heat or air is on it thumps and it sounds like it is in the dash. I can turn the heat/air settings to off and it will continue to thump some days worse than others. Sometimes I can adjust the front temp dial one way and the rear another (one to heat one to cold) and the thump will slow (again sometimes). Please tell me what I need to do before I have to go wothout heat this winter!
Tuesday, December 20th, 2016 AT 6:10 PM (Merged)
BLACKOP555
  • EXPERT
Sounds like one of your blend doors inside the HVAC duct work has went out under the dash.
Its what controls posiiton of the door and where the air goes to get heated or cooled. Its quite an undertaking to take apart the dash to get to it to fix the problem.
I can give you the steps tho if you would like.
ONEAGLE
Hey blackop555 I think I am having the same problem would you mind posting the instructions so I can fix the blend door in my windstar.
Thanks
FIXITMR
  • EXPERT
Definately sounds like blend door failure. Probably needs new actuator motor.
MRTANGOGUY
  • 2003 FORD WINDSTAR
Heater problem
2003 Ford Windstar V6 Front Wheel Drive Automatic 78908 miles
heater doesn't work. Banging sound coming from under dash. The pitch of the sound changes as I move the heat control from hot to cold. But still no heat at all. I bealaeve it is a problem with the control module but not sure what to do to check. I would be grateful for all help. Thank You.
MACMANJIM
I have the same problem with a 2003 Windstar It makes a clicking sound when the heat is on and blows cold air in the front. It sounds like it is coming from the plenum under the dash. If I select a certain heat range for the front slider, it will stop. Any clues?
04BOLT
Blend door actuator
JRM0006
  • FORD WINDSTAR
1997 Ford Windstar 3.0 197,000 miles. The heater is not working at all. The blower, and AC work, but when I turn the temperature control knob to the hot position, the air stays cold. Both lines coming through the fire wall to the heater core are hot, and the heat guage is reading at the half way mark. I have plenty of coolant. Might this be a control problem in the switch? Where should I look? Thanks a bunch. Just another poor shadetree mech.
BMRFIXIT
  • EXPERT
Do you hear any clicking when switching to heat?
Most common: you need a blend door motor
TWISTEDTWIN69
  • 6 CYL
  • FWD
  • 115,000 MILES
Heater problem
2002 Ford Windstar 6 cyl Front Wheel Drive Automatic 115000 miles
my heater blows air as cold as if A/C is on. Is there a fuse I should check?
  • EXPERT
Is the coolant full?
MLGIVINGS
  • 1996 FORD WINDSTAR
Heater problem
1996 Ford Windstar 6 cyl Front Wheel Drive 140, 00 miles
My heat is not working :(
The blower is blowing out cold air.
There is coolant in the van, and it's not over heating, so my next though was the fuses. I don't have the owners manual so I printed pictures of the fuse box diagrams, but I don't know which fuses to replace. Any suggestions?
BLACKOP555
  • EXPERT
Fuses wont affect the heating unless the motor isnt turning on. But it is so we can eliminate fuses.
What I want you to do is get the engine hot and turn the heat and everything full blast.
Pop the hood and check the heater core hoses. Both hot? Both cold? One hot one warm one hot one cold?
CLH
  • V8
  • 168,000 MILES
I have a 1996 Windstar van. A few days ago the heater stopped working. When my husband got home he checked the coolant level which was good and drove the car and it started to register hot. When this happened coolant started to bubble out.(Of the place you put coolant in) he turned the car off right away.(He was back home and pulled it in the garage). (He didnt drive it hot). Had a friend come over and put on a new themostat. I had heat after a few minutes of driving it and the car never got hot. The next time I went to drive it I didnt have any heat again. The car is not getting hot when I drive it but still no heat. The friend also noticed that the radiator fans come on the minute I start the car and stay on. Not sure if this could be the problem. Background on this car is. I only drive this car to work which is a total of 10 miles. (Dont trust it to go too far). The abs, brake light, and check engine light have been on for a couple of years now. I dont want to put alot of money in this car because of it being so old. Any suggestions as to why I have no heat. Thanks in advance for your response.
CARADIODOC
  • EXPERT
You're causing part of the problem by ignoring the Check Engine light. The Engine Computer detected a problem that could have been very minor at first, set a diagnostic fault code, and turned the Check Engine light on to tell you. There is always a long list of conditions that must be met to set a fault code, and one of them is that certain other codes can't already be set. The computer compares many sensor readings and operating conditions to determine when there's a problem. When a problem is detected and a fault code is set, many of the other tests that use that criteria as a reference will be suspended. If another problem develops that could be serious, it won't be detected and you'll never know about it until something happens.
Also, your mechanic will have no way of knowing of some of these additional problems. Once he diagnoses and repairs what is known to be needed, the rest of the tests will resume and additional problems will be detected for the first time. Those tests often don't run right away. They can take miles or days after leaving the repair shop. You're incorrectly convinced the mechanic didn't do a proper job, but he had no way of knowing another problem existed unless there was some other symptom.
Driving for years with the brake light on is also a very bad idea. That can land you in a courtroom very easily when the other guy ran the red light and caused a crash. Any lawyer or insurance investigator knows to look for ignored warning lights, altered ride height, non-standard wheels and tires, and any other modifications they can use to show a jury that you were partly at fault for the crash because you were less able to avoid it.
The anti-lock brake warning light means that computer detected a problem and set its own diagnostic fault code, and the computer turned the system off. That is simply an add-on feature that has been disabled leaving you with the same standard brake system all vehicles have, but the red brake warning light refers to that base brake system. It could be as simple as low brake fluid level, which will eventually send you sailing through a stop sign. It could also be as simple as a parking brake that's not fully-released. That's real common on all Ford products. They are well-known for parking brake cables that become rusted and stick. The third thing the red light can point to is a failure in one of the two hydraulic systems. That means you're driving with half the brakes. Boy, a lawyer would wring his hands and lick his chops if his investigator found that.
I can understand not wanting to stick money into a Ford product. We read that all the time, but you're referring to things that can happen on any vehicle at any time. Age and value have nothing to do with fixing brake and emissions problems. My daily driver is an '88 Grand Caravan, and I'd stick any amount in it to keep it going. There are no newer vehicles that could be more reliable. Anything I'd spend on repairs is peanuts compared to one new-car payment. You mentioned not trusting your van. I don't trust newer vehicles with computers hung onto every conceivable system that never needed computers before. I have newer cars, but I rarely drive them any further than I'm willing to walk back home.
Windstars are also under a recall for rear axles falling off. Most shops will not do the repairs unless the suspension and brake systems function as designed. They are required to address anything that would restrict proper operation, but that additional parts and labor aren't part of the recall so Ford won't cover those charges.
At the very least, find out why the red Brake light is on. If the engine falls apart, you just coast to the side of the road. If the brakes quit, you'll involve other people. That's when the lawyers come running. Check that the parking brake is fully-released, then check the brake fluid level. If it's just a little low, don't add any. If it's real low, we need to figure out where it's going. That light needs to be off so if a problem develops in part of the brake system, you'll know about it right away.
For the Check Engine light, start by having the fault codes read and recorded. Some manufacturers make reading them yourself real easy, but for yours the best is to visit an auto parts store. Many of them will read engine codes for free. Be aware those codes never say to replace parts or that they're defective. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. It's best to get the exact fault code number(s). The generic descriptions can leave room for interpretation.
TEDDYBOY
  • FORD WINDSTAR
1995 Windstar GL 3.8l 215,000 km. I have replaced heater core, thermostat and put in a used control panel for the blower, temp selector, but still NO HEAT! Engine is running at normal operating temp. Blower fan is working air selector switch is working. What to do? Heat WAS working fine until one day NO HEAT at all.
BRUCE HUNT
  • EXPERT
It could be a heater core problem but I would suspect that the valve that opens to let the heat in to the core has failed to open for a variety of reasons. Is the hose hot that services the heater? And is the return hose cool?
