No heat from heater
BHASWATI
  • 2002 FORD WINDSTAR
My car heating stopped working, only cold air is coming out. Also there is a flapping noise. The seat warmer is working though.
Tuesday, December 20th, 2016 AT 9:09 PM (Merged)
FIXITMR
Did ya get it fixed? What was it?
JERED
  • 2003 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 88,745 MILES
Banging noise coming from under the dash. Will not blow warm air only cold air. Any ideas as to where I could start?
DRCRANKNWRENCH
  • EXPERT
There is a door flap on the heater box located under the dash.
It is generally it is controlled by a cable. The cable comes off sometimes and the heater core flow cannot be directed to the interior and cold air comes with it.
Also check the fresh air recirculation door. It is cable actuated as well.
I hope this information helps.
STEVE 123
  • 1998 FORD WINDSTAR
  • 6 CYL
  • 135,000 MILES
Heater problem
1998 Ford Windstar 6 cyl Two Wheel Drive Automatic 135000 miles
Hi I have no heat at all up front but have heat in the rear was just working before. NEED HELP
Tuesday, December 20th, 2016 AT 9:10 PM (Merged)
  • EXPERT
Hi: make sure the blend door is opening.
Tuesday, December 20th, 2016 AT 9:11 PM (Merged)
BRGRAFTON
  • 2000 FORD WINDSTAR
  • 6 CYL
  • AWD
  • 110,000 MILES
Heater problem
2000 Ford Windstar 6 cyl All Wheel Drive Automatic 110000 miles
vav ac started to make a funny noise sounds like some kind of switch switching on and off today heat or defrost blowing out cool air no heat back heat works ok still making funny noise unless switch is in certan possition please help
  • EXPERT
Is the sound coming from under the dash?
JENNIFERTUTTLE
  • 1999 FORD WINDSTAR
  • 220,000 MILES
What would make my van chug and the rear heater blow out cold air
HMAC300
  • EXPERT
Check coolant level first if low have pressure checked for leaks, then check the actuator on the rear heater, it is to the left of the rear seat. There are two and either one or both cold be bad. Make sure to check fuses as well. Hey are #8-16-&23 on fuse panel left side of dash
EWHITE14
  • 6 CYL
  • 160,000 MILES
My car heater blows out cold air and makes a knocking sound.
  • EXPERT
Make sure the coolant is full. Make sure the engine is running at a normal operating temp. Next, with the engine running, hot, and the heater on, feel both heater core hoses. Both should be hot. If only one is, flush the heater core. If both are hot, chances are there is a problem with the blend door. If the knocking sound is under the dash, the blend door is my first guess. If the noise is coming from the engine, that is a different situation and most likely involves internal engine bearing issues.
JUNKO
  • 123,846 MILES
How to fix the heater in a ford windstar? The air just blow cold.
  • EXPERT
Make sure the coolant is full. Check to make sure the engine is operating at a normal operating temp. If it is, start the engine, let it warm up with the heater on high, and feel both heater core hoses. If they are both hot, check the blend door. If only one is hot, flush the heater core.
DELORISWILL36
  • 6 CYL
  • 4WD
  • 190,000 MILES
Heater problem
2002 Ford Windstar 6 cyl Four Wheel Drive Automatic 190000 miles
Hi my name is Deloris and I am haveing problem with my heat. My winderstar van blows out cold air in front and hot in the back. Do I need to replace the front or could it be a relay.
DAVE H
The relay is fine if the motor is blowing air. Have your mechanic check the heater core is not blocked. Theres no air in the system. No leaks. Pressure test system.
RELHARTS
  • 170 MILES
Fans run but heat not present front or back control speed for front works rear control stuck full speed radiator is full temp gage on normal still no heat
Tuesday, December 20th, 2016 AT 9:12 PM (Merged)
  • EXPERT
Check blend air door. Check to make sure there is flow through the heater core.
  • 150,000 MILES
My heat does not work and there is a clicking nose in the vents it sounds like. The a/c works though.
JDL
  • EXPERT
Maybe an actuator under the dash has a problem?The blower motor works ok? Does the engine reach normal operating temp? Are the heater hoses, hot?
