1999 Ford Windstar ABS light on
BURISTER
  • 1999 FORD WINDSTAR
  • 6 CYL
  • 95,000 MILES
ABS light comes on and goes off after restarting the car, any ideas what might be the cause. Where are the sensors that affect the abs light.
Also the door light is on, any idea where are the swithces that control it
Do you
have the same problem?
Sunday, March 23rd, 2008 AT 10:15 AM
MASTER TECH DAN
The sensors are at the wheels you need to see what code you have to see which one or ones are bad usually the rears and the rings on the halfshafts crack the door lite is a simple fix spay a lubricant in all of the door latches and open and close them a few times you can see which door it is by turning the ing to on but not running and see what door does not chime
Tuesday, March 25th, 2008 AT 7:55 PM
Recommended Guides
