1998 Ford Windstar CV replace
BASISANTA22
  • 1998 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 168,000 MILES
Dear Sr I like to know how to replace the front axles,
I drop the hold drive train to replace the engine and transmition.
I`m 75 year old retire European car mechanic.
Thanks.
Do you
have the same problem?
Thursday, January 15th, 2009 AT 11:38 AM
DAVE H
  • EXPERT
AXLE SHAFT (WINDSTAR)
Removal (Axle Shaft Assembly)
Raise and support vehicle. Remove wheel assembly. Remove axle nut and washer. Discard nut. Remove anti-lock sensor retaining bolt, and position aside. Remove lower ball joint pinch bolt and nut, and discard. Separate ball joint from steering knuckle.
If necessary, disconnect stabilizer bar at control arm. Install Hub Remover/Installer (T81P-1104-C) assembly, and push CV joint out of hub assembly. See Fig. 2 . Using pry bar, separate inner joint from transmission. Remove axle shaft from vehicle.
Fig. 2: Separating CV Joint & Knuckle Assembly
Courtesy of FORD MOTOR CO.
http://www.2carpros.com/forum/automotive_pictures/266999_cv_1.jpg
Installation
Replace circlip on transaxle end of axle shaft. Insert axle shaft into transmission. Ensure circlip is fully engaged in transaxle. If difficulty is encountered engaging axle shaft into transmission, tap on outer CV joint with plastic or rubber mallet.
Feed outer CV joint stub shaft into hub as far as possible. To complete installation, reverse removal procedure using NEW axle nut and NEW lower ball joint pinch bolt and nut. Tighten all nuts and bolts to specification.
Thursday, January 15th, 2009 AT 11:50 AM
Recommended Guides
