1996 Ford Truck Not starting
NEO78
  • 1996 FORD TRUCK
Electrical problem
1996 Ford Truck V8 Four Wheel Drive Automatic
I have a 1996 Ford F350 that will not start in park, but will start in neutral. The shift lever on the colum is loose.
Is there a lockout switch and where can I find it?
Do you
have the same problem?
Friday, February 27th, 2009 AT 4:45 AM
Check the transmission range sensor and linkage
Friday, February 27th, 2009 AT 4:50 AM
Recommended Guides
