1994 Ford Thunderbird
CASSIEDENAPOLI
  • 1994 FORD THUNDERBIRD
Heater problem
1994 Ford Thunderbird V8 Automatic? Miles
if I turn the heater on it doesnt come on right away almost like it sticks what would be wrong
Do you
have the same problem?
Tuesday, February 17th, 2009 AT 7:33 AM
JACK42
You mean the fan does blow right away? Could be the fan motor. Does it ever not work? If so it is located under the dash pass side, remove plastic shield and tap on it to see if it comes to life
Tuesday, February 17th, 2009 AT 7:44 AM
CASSIEDENAPOLI
If you turn it on it will blow out a little bit but then it will automatically just start coming on all the way one time we went over a big bump and it came on full blast
Tuesday, February 17th, 2009 AT 7:48 AM
CASSIEDENAPOLI
Ok I turn the heater on high it comes on a little futher down the road it will just start worker full blast almost like it has a relay problem or something not sure or maybe a hose could be loose or something
Tuesday, February 17th, 2009 AT 7:55 AM
JACK42
Sometimes when themotors are going out they get sticky like that. Remove the shield under the dash on the passenger side and find the motor. When it doesnt turn on, tap the bottom of it with something and see if it comes on. We will start with the usual problems and go from there
Tuesday, February 17th, 2009 AT 7:59 AM
CASSIEDENAPOLI
Thank you so much for your quick reply I will let you know if I have anymore problems or if that resolves the issue. If not do I need a new blower motor and does it have a relay?
Tuesday, February 17th, 2009 AT 8:13 AM
JACK42
I dont see any relays in the system. Most likely will be the blower motor, but check the resistor too, it is located next to the blower motor, follow the wires back to it. The resistor controls fan speed, it may be shorted too
Wednesday, February 18th, 2009 AT 7:40 AM
CASSIEDENAPOLI
Would the resistor be the same thing as a pwm blower control
Wednesday, February 18th, 2009 AT 7:46 AM
JACK42
Is this an automatic system or manual? The resistor is called that, a resistor or fan speed controller if it is solid state
Wednesday, February 18th, 2009 AT 8:05 AM
CASSIEDENAPOLI
It is a automatic so what is a blower control then
Wednesday, February 18th, 2009 AT 8:22 AM
CASSIEDENAPOLI
Here is a pic of it
http://www.2carpros.com/forum/automotive_pictures/319064_002_1.jpg
Wednesday, February 18th, 2009 AT 8:24 AM
JACK42
Blower motor speed controller
try motor first
Wednesday, February 18th, 2009 AT 8:48 AM
CASSIEDENAPOLI
I have another question while driving I hear a clinging noise in my front tires any suggestions?
Wednesday, February 18th, 2009 AT 4:22 PM
Recommended Guides
