1993 T-Bird V6 3.8 LX Not Charging?
ASOTO98
  • 1993 FORD THUNDERBIRD
I tested the alternater at auto zone and it passed. I checked all fuses inside the car and engine compartment. I tested the harness of the alternator for bad fuse links and passed. The car starts and runs normal, but it won't charge the battery, alternator gauges is on the negetive side. The batery is OK. Can it be the computer? Need Help!. I scaned the computer codes and came out empty.
Do you
have the same problem?
Tuesday, July 24th, 2007 AT 8:17 PM
POET042005
Check the connections to your alternator make sure they are not corroded.
Next buy a cheap test light and check the connections at the alternator for 12 volt power.
Third if these two are fine then you have a short in the system some were.
Before the third step try the first two and get back with me. Then we will go over the third step more closely in detail.
Richard
Friday, August 17th, 2007 AT 11:34 AM
Recommended Guides
