1986 Ford Thunderbird Turns over but doesn't start
GANNIER
  • 1986 FORD THUNDERBIRD
Electrical problem
1986 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
I have a 1986 T-Bird that turns over and fires but doesn't start. I had previously replaced the ignition module and it ran fine. While letting it run to check for coolant leaks it busted a coolant hose, after replaceing hose it will not start. Please help.
Do you
have the same problem?
Friday, April 16th, 2010 AT 8:04 AM
  • EXPERT
Are you getting spark and fuel to the engine?
Friday, May 14th, 2010 AT 11:27 AM
Recommended Guides
