Why is my engine misfiring?
KBREFERE
  • 1997 FORD TAURUS
After the car has been warmed up about 1 hours of driving the speedometer drops to 0, the tachometer still works and revs high. The car seems to not shift gears and when it does it jerks and makes a loud cluck into gear but the speedometer still reads 0. The check engine light has now come on but it did not in the beginning.
Saturday, July 17th, 2010 AT 6:55 AM
MERLIN2021
  • 17,250 POSTS
This sounds like the ignition coil is out which is common here is a video and some guides to help fix it.
https://youtu.be/iDgXwKA-IIc
It is possible you need a tune up but it could be a fuel injector as well we should run the codes to see what's going on first.
and
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Saturday, July 17th, 2010 AT 7:47 AM
*KEN*
  • 1997 FORD TAURUS
Engine Performance problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic 197k miles
Car starts and idles fine. No engine codes. Around 45mph I get a intermittent misfire. The car stumble every 15-30 seconds. It will do it at 55mph also but not near as frequent. Have replaced plugs and wires, no help. All the old plugs looked the same and prett clean. Any help? Fuel or Ignition? Thanx
Saturday, January 16th, 2021 AT 9:47 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Is it a missfire in more than one cylinder? Check coil. And fuel pressure.
*KEN*
It is so small of a stumble, I would say one cylinder. Fuel pressure, wouldn't that make it worse at 55? Six coils, how do I check them?
MERLIN2021
  • 17,250 POSTS
If your check engine light comes on it will tell you which cylinder is missfiring.P0301- #1 cylinder 0302 #2 cyl and so on, then you can pull the COP for that cylinder and cvisually inspect it for any damage to the plug boot.
*KEN*
No Check Engine Light, no Codes.?
JRWRIGHT
  • 1997 FORD TAURUS
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic 130k miles
My Taurus runs fine about 75% of the time and misfires about 25%. It will run fine for 10-15 minutes and then misfire for a few minutes and then go back to running fine. My code reader says codes # P0352 "ignition coil no. 2 primary circuit fault" and #P0303 "cylinder #3 misfire detected". I replaced the coil, spark plug wires and the spark plug to cylinder #3 and it still does the same thing. I removed the spark plug wire while it was misfiring and it certainly is cylinder # 3 that is the problem.
Got a solution?
2CARPRO JACK
  • 11,533 POSTS
If it has good compression, and good spark, teh only thing left is fuel. This may be an injector that is slowly going away, working sometimes but not always.I have seen injectors set ignition fault codes before.
JRWRIGHT
Hmm, sounds like you're guessing too!
I only presume that it's got good compression since compression is not usually a part time thing. I don't know whether its got a spark on cyl. 3 or not, I only know that I replaced the coil, wires and cyl. #3 plug. What ever signals the coil to spark that cyl. May be out of whack (it used to be the rotor in the distributor cap, which they don't have any more). How do I figure that out?
How can you find out if it's the fuel injector without having to go to the trouble of replacing it?
2CARPRO JACK
  • 11,533 POSTS
To see if it is the injector, you would need the proper scan tool to watch the injector waveform for that cylinder, when it is acting up. If the PCM was having an issue firing that coil, it would give a driver code most likely.I wouldnt think it was compression, like you said it comes and goes, tht usually goes and doesnt come back. Yes, I am kind of guessing, without having the car to drive and watch on my scanner, its all guess work. Lol
ALLANO24
  • 1997 FORD TAURUS
  • 6 CYL
  • FWD
  • 113,000 MILES
My car is misfireing on the # 1 cylinder I cheaked the pluges and wires. The coil look like its new. What could the problem be im out of ideas. Thank you Allan Zolinski
BLACKOP555
  • 10,371 POSTS
Switch the #1 plug and plug wire with a different cylinder, does problem move to the other cylinder? If so repalce the plug and wire. If not check the injector and the compression of that said cylinder.
TMCG
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 11,000 MILES
Greetings. This is a 3.0 GL model. Recent blown head gasket between #1 and 2 cylinder. While off I had the heads pressure tested and magnafluxed; discovered several cracks. Acquired a set of aftermarket heads, and populated them with the old valves after cutting, new seals, etc. Put it back together and it started posting 302 code w/check engine light blinking. Replaced plugs, wires and swapped coil pack with a known good one. Code returned after 5-10 miles driving. A miss can be felt during driving. I decided to remove and clean the injectors. All injector coil resistance consistent around 19 ohms.
New seals, pintles and filters as well. Upon re installation I moved the #2 injector to the #4 cylinder position. Cleared the codes. After a short drive it posted codes of both 302 and 304. I plan to move the injector from #4 back to #2 but have yet to do so. There are no apparent vacuum leaks, and least none observable. Compression is consistent and steady between 155 and 160, with the exception of #2 which is 125lbs. Which seems odd. At this point I'm just soliciting opinions to see if I'm on the right track or overlooked something that could be obvious to you. Any suggestions would really be appreciated. Thanks.
Saturday, January 16th, 2021 AT 9:48 AM (Merged)
MERLIN2021
  • 17,250 POSTS
That #2injector may be bad, but the wiring to the #2 is also suspect, when the problem moved with the injector, that tells you the injector is either bad, or clogged, and the fact that the #2 stayed bad, the wiring could be a problem.
TMCG
Thanks. I was leaning toward that possibility. Two questions though. Do you know where I could get an illustration of the individual injector wring that corresponds to contact points on the ECM plug? And secondly, any thoughts on that #2 cylinder having compression about 20% less than the others?
MERLIN2021
  • 17,250 POSTS
If the ompression is less than 15 psi of the next lowest reading, pull the head and re check the grind of the valves, or make sure the valve lash is right, overhaed cam folower may be the wrong size, any valve noise? Also to eliminate a ring problem, did you wet test the compresion too? Put a few drops of oil in the cylinder and recheck, All plugs removed please!
TMCG
I just wanted to follow up on this. I checked the valves in #2 just to be sure the rockers were torqued properly since there's no valve adjustment on this engine; all good. While I had it apart I swapped injector 4 back to #2. When reinstalling the upper intake manifold it seemed to not seat properly. After rocking it around a bit it appeared to seat fully. When I started it up, miss was gone and the engine ran smoothly. Drove it for about 50 miles to test it and it continued to run strong; no miss and no 30x codes. I can only think that the upper intake manifold was not seated properly on the first go round.
After a couple days new codes postes; 0430 and 1744 but I think that's unrelated. Just wanted to let you know the outcome.
By the way, for a 1744 is the TCC solenoid actuator internal or external to the trans?
MERLIN2021
  • 17,250 POSTS
First, if this is a 95' it should have OBDI and you are giving me OBDII 96' and newer codes?
https://www.2carpros.com/forum/automotive_pictures/62217_taurus_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_taurusc_1.jpg
TMCG
Merlin, first off, right you are on the year. It's my son's car and I just had 1995 in my head.
Anyway your reply is quite a mouthful and I appreciate the detail you provided. Considering the specialized equipment, familiarity with what a Quick or KOEO test is for example, detailed wiring and connector diagrams or the Maintenance Analysis procedures of the manufacturer; you made it very apparent that I would be biting off more than I could chew if I started messing with the transmission.
Thanks again for all your help. Although it appears to be running/shifting fine over the past 500 miles or so, I guess he'll just have to drive it until the trans gives it up. Tom
MERLIN2021
  • 17,250 POSTS
OK.
