2002 Taurus 97000 miles 3.0 flex fuel. Instrument panel lights won't light when headlights are turned on. Floor shift ind, radio and heat A/C lights come on and work fine. When headlights are turned on, only l & r turnsignal lights illuminate. All gauges and warning lights work fine. Was told its most likely headlight switch but want to be sure I shell out over $100.
SPONSORED LINKS
Do you
have the same problem?
Sunday, March 11th, 2007 AT 5:27 PM
MERLIN2021
EXPERT
Dumb question, but, is the dial turned up? Also check the instrument cluster fuse. If your ambitiuos
and have a test light, unplug the connector and check for power!
