Engine noise when atmospheric moisture goes up or when rains
RAGHUJOSHI
  • FORD TAURUS
I have a Ford Taurus 2001, 129K V6 engine. I have noticed that there will be a noise(as if some thing is rotating and hitting the engine ). When I got it checked, it was thought that a camshaft timer and base were the problem. After replacement, I did not observe any great change. This noise particularly occurs when there is a lot of moisture in the air or when it rains. It does not occur in extreme cold or extreme heat or normal weather. I feel it has to do something with moisture content. Can I get some insights into this.
Do you
have the same problem?
Monday, March 19th, 2007 AT 10:08 PM
JACK42
Carefully inspect the drive belt and tensioner.
Thursday, March 22nd, 2007 AT 3:46 PM
Recommended Guides
