Intake Manifold tools
SHARRON TURNAGE-SMITH
  • 2006 FORD TAURUS
  • 6 CYL
  • 250,000 MILES
I need to remove the intake manifold to have it replaced due to a cracked in it what tools do I need for it?
Saturday, May 28th, 2016 AT 10:03 PM
HMAC300
  • 48,601 POSTS
Normal hand tools sockets and wrenches. You may need fuel rail tools available at auto parts. All sockets and wrenches are metric 8mm-15mm depending on whether it is upper or lower manifold.
Sunday, May 29th, 2016 AT 8:32 AM
IMDASHIZNT
  • FORD TAURUS
I have a 24valve dohc. It has 105,000.
I need to change my spark plug wires but have to take off the intake manifold to reach the back 3 wires. I need to know what the torque spec's are.
Tuesday, May 14th, 2019 AT 2:30 PM (Merged)
BLMO
  • 72 POSTS
The tourqe is about 90 inch-pounds. I've been using about 8 foot-pounds, which is pretty close. Please let us know if you need anything else to get the problem fixed.
READY99
  • 2006 FORD TAURUS
  • 6 CYL
  • FWD
  • MANUAL
  • 102,000 MILES
My o6 TAURUS check engine lite came on so spark plugs, wires and dist cap was replace. A couple of weeks later car was running rough and no power. Notice pinholes on intake manifold assy. Use JB weld for a emergency fix that last for maybe 10 miles before new holes appear. Had new manifold intake install and last half a day before new pinholes appear again on new parts. With the pinholes on manifold assy is causing engine I believe is losing engine compression. What could be possible causing this problem?
Tuesday, May 14th, 2019 AT 2:31 PM (Merged)
  • 31,938 POSTS
Hi there,
Thank you for the donation,
I have never heard of this before, there are often problems with alloy castings and porosity, but not pin holes appearing like this, can you post any pics?
Mark (mhpautos)
