2003 Ford Taurus Transmission
JACOBJOHNSTON
  • 2003 FORD TAURUS
Transmission problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic
The car was parked and the next day would not go in any gear. Have checked fuses and relays and all seem to be normal. Can see the linkage moving while someone is moving the gear shifter looks like it is moving normally. Is there a sensor that could have gone out because they said they have not had any problems. Transmission fluid is at the normal range on dip stick and does not look burnt. CHECK ENGINE LIGHT HAD BEEN ON FOR A WHILE ACCORDING TO THE OWNER.
Do you
have the same problem?
Monday, October 4th, 2010 AT 7:50 AM
  • EXPERT
Has the check engine light come on?
Monday, October 4th, 2010 AT 10:16 AM
Recommended Guides
