2003 Ford Taurus no forward or reverse
FIREMAN2321
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 78,561 MILES
Yes this car just quit while running stopped at a red light proceeded through and went like to nothing. Motor runs fine but no forward or reverse. Checked codes in trans and no dtc and same with engine. The trans is a metric a 4x something. Dropped fluid no metal nothing no smell had been shifting fine and doing good no lound noise or anything like that. Is it possible can be tc
Do you
have the same problem?
Tuesday, July 14th, 2009 AT 11:17 AM
CLAYSTER67
Yes possibly the torque convertor. I have a 1999 that did the same thing and the oil pump shaft is driven by the convertor. The spline insert where the oil pump shaft goes into convertor was stripped out. To check before pulling transmission, check the oil pressure on transmission, there is a port located somewhere where on trans where the pressure can be checked.
Friday, July 17th, 2009 AT 7:59 PM
Recommended Guides
