Engine not starting
RMOORE009
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 135,000 MILES
I am having problems with my car. When I go to start it, it will turn over making a grinding noise but wont start. Every time I try to start it, it makes a grinding noise. It was working fine yesterday afternoon.
Friday, June 5th, 2009 AT 8:54 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,884 POSTS
It sounds like the battery is low on charge if it is more than three years old I would replace it. If the battery is good then the starter needs replacement. Here is a guide that will help you see what you are in for when doing the job:
I would remove the battery and take it to your local parts store and have it tested to make sure it is holding a good load. Call around first to make sure they test battery's and starters. Then if that tests okay remove the starter and have them test it. Let me know how it goes.
Please let us know what you find so it will help others.
Best, Ken
Tuesday, February 28th, 2017 AT 11:49 AM
