2003 Ford Taurus engine misses
GAFIXER
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 129,000 MILES
Replaced heads and lower manifold, engine sounds pretty good can't track down engine miss and rough idle.
Do you
have the same problem?
Wednesday, November 3rd, 2010 AT 10:59 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Manifold absolute pressure sensor
Thursday, November 4th, 2010 AT 2:46 AM
Recommended Guides
