2003 Ford Taurus Car revs up but doesn't Move
COMETS911
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 120,000 MILES
I was driving down the road just fine and I step on the gas and all the car does is rev the engine. I get to a stop sign and step on the gas and all the car does is rev the engine. I also tried to put it in First gear and reverse and it's the same. The car starts up fine, everything works fine except the car doesn't want to move.
Do you
have the same problem?
Friday, May 7th, 2010 AT 9:35 PM
  • EXPERT
Hi there,
Thank you for the donation,
What you have to do first is find out if there is any pump pressure, as the torque converter or oil pump may have failed, this should be done by a transmission specialist, as long as the transmission is actually selecting gears, ans there is oil in the trans, any further tests will require specialist equipment.
Mark (mhpautos)
Friday, May 7th, 2010 AT 10:32 PM
Recommended Guides
