2002 Ford Taurus plugs
TRACY1964
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 130,000 MILES
How's the easiest way to change the 3 back spark plugs
Do you
have the same problem?
Tuesday, April 21st, 2009 AT 12:49 PM
TORNADO
Hi Tracy
I did replace the spark plugs on my Taurus 02 without a problem.
I did it with a 5/8 " extension and a normal Craftsman 8" wrench
The one in the middle (back in the middle) is the one that takes a little more time.
I recommend you to use original Motorcraft ones.
I wanted to use another brand and it didn't work well
Good luck to you
Friday, April 24th, 2009 AT 7:21 PM
Recommended Guides
