2001 Ford Taurus P1309 Error Code- CAM Sensor
RSSFAIRCLOTH
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 80,000 MILES
Addendum to the response previously posted which instructed to check cam sensor :
Cam sensor assembly was replaced 5,000 miles ago and the cam sensor has been replaced one time since then. Is it possible that the cam sensor assembly has shifted from the top dead center position and this is the cause of the multiple misfire error code?
Last time the cam sensor was replaced, it came up as a "P0301" code - which read as "Misfire on No. 1 cylinder." Most recent scan indicates cam sensor is okay.
Any info. Would be most helpful! Thank you!
We did access the definition "misfire monitor disabled" - However, we cannot find anything to define WHAT needs to be replaced or fixed. Please advise.
Do you
have the same problem?
Saturday, January 3rd, 2009 AT 10:24 AM
BMRFIXIT
  • EXPERT
Check cam sensor
remove and inspect
Sunday, January 4th, 2009 AT 8:48 AM
Recommended Guides
