2001 Ford Taurus Occasional engine miss
ROBERT BUTTA
  • 2001 FORD TAURUS
Engine Performance problem
2001 Ford Taurus Front Wheel Drive Automatic
There is an occasional engine miss while in idle or drive.
Had a tuneup at 80000 miles (Midas Auto Service) but the problem still persists.
Do you
have the same problem?
Tuesday, August 10th, 2010 AT 2:45 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Tuesday, August 10th, 2010 AT 3:01 PM
Recommended Guides
