2001 Ford Taurus Car is missing on initial cranking
JMEDIC61
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 50,000 MILES
I have a 2001 Ford Taurus and it runs a little rough when you first crank it up. I can crank it anytime of the day and when I put it in gear it starts missing and running rough. After driving it for a little bit it runs a lot better. Have changed the plugs, wires, fuel and air filter. Seemed to help some but still doing it. Sometime it is not as bad as others. Any ideas?
Do you
have the same problem?
Friday, February 6th, 2009 AT 5:35 PM
BMRFIXIT
  • EXPERT
Check and suspect intake manifold gasket leak
Friday, February 6th, 2009 AT 9:45 PM
Recommended Guides
