Thermostat replacement?
ANDREASTEVERS
  • 2005 FORD TAURUS
  • 6 CYL
  • FWD
  • 79,000 MILES
The thermostat was replaced about 1 month ago and my engine just started overheating again. Upon inspection I noticed that the coolant was leaking where the seal is for the water hose connection and the intake manifold. I replace the thermostat and the gasket yet again and it is still leaking. I am not sure what to try now.
Friday, May 29th, 2009 AT 7:26 PM
BMRFIXIT
  • 19,053 POSTS
You must have a bad gasket here is a guide to help you change out the thermostat with instructions below to show you how on your car.
Saturday, May 30th, 2009 AT 4:05 AM
MARKOS1979MDG
  • 2003 FORD TAURUS
  • V6
  • 210,000 MILES
I replaced the thermostat. But it's still leaking. Is there suppose to be some kind sealant I was to put on?
Wednesday, October 21st, 2020 AT 9:59 AM (Merged)
More than likely one of the mounting surfaces is not true any longer and so your gasket can no longer take up that difference. I would suggest just using Motorcraft Silicone TA-29. This is meant to resist oils and coolant. I use it all the time to seal thermostat all the time.
Let me know if you have questions. Thanks
JAMESO
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 100,000 MILES
How do I change my thermostat?
  • 108,133 POSTS
Hi:
drain the radiator. Follow the upper rad hose to the engine. It will end at the t-stat housing. Remove the rad hose clamp, then the hose. Now remove the t-stat housing. Under the housing you will find the t-stat. Pay attention to the direction the old stat is sitting in and replace the new one the same way. Just reverse the sequence to replace it.
SIERRA KEATLEY
  • 2002 FORD TAURUS
  • 6 CYL
  • 65,000 MILES
Thermostat location
BMRFIXIT
  • 19,053 POSTS
THERMOSTAT - 3.0L (4V)
Removal and Installation
1. Raise and support vehicle. For additional information.
2. Remove the front splash shield
3. Drain the cooling system.
4. Remove the cooling tube bolt.
5. Lower the vehicle.
6. Remove the radiator upper cooling tube bolt.
7. Disconnect the upper radiator hose and engine vent hose..
8. Remove the two bolts, and separate the radiator tube from the thermostat housing. Remove the thermostat.
9. To install, reverse the removal procedure.
L(2V) locate upper hose and thermostat housing remove 3 bolts holding housing remove and replace thermostat
BOBESSIE
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 92,000 MILES
2002 ford taurus sel w/24valve dohc, not heating but core not leaking and coolant is not low hoses seem intact can it be the thermostat
MMPRINCE4000
  • 8,549 POSTS
Possible thermostat, but with engine at temp, quickly touch both heater core hoses, if one is hot and one cool/warm, then core is blocked. If both are cool/warm then thermostat.
BOBESSIE
Could it also be the heater blend door or the heater blend door lever as apparently they fail easily
MMIKEC9
  • 2002 FORD TAURUS
Engine Mechanical problem
2002 Ford Taurus Two Wheel Drive Automatic 100000 miles
need to locate and replace thermostat
BLUELIGHTNIN6
  • 16,542 POSTS
3.0 DOHC engine.
Drain the coolant until the level of the coolant is below the level of the thermostat.
Raise the vehicle and support it with jackstands.
Disconnect the lower radiator hose from the water inlet connection.
Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
Clean the water inlet connection mating surfaces.
Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
Connect the lower radiator hose to the water inlet connection.
Fill the engine with coolant, start the engine and check for leaks.
Stop the engine and top off the coolant recovery reservoir as necessary.
ANGELMCCOLLUM
  • 2001 FORD TAURUS
2001 Ford Taurus 6 cyl Automatic 180000 miles
My husband was checking my thermostat to make sure it was working correctly, but when he was removing it he broke the bolt. He cut the bolt flush and tried to drill it threw then rethread it. When doing that he noticed that he went some what at an angle and not straight threw. What are we to do now? Can it be fixed?
Wednesday, October 21st, 2020 AT 10:00 AM (Merged)
  • 31,938 POSTS
Hi there,
You can still remove this broken bolt with a good quality stud extractor, ask you local tool supply to show you what is available if in doubt get a mechanic to do this for you.
Mark (mhpautos)
RONTANK71
  • 2001 FORD TAURUS
May have a warped thermostat cover.
Wednesday, October 21st, 2020 AT 10:01 AM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
No. See images.
REEVESLG
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 165,000 MILES
Where is the thermostat located on the engine
Drain the engine cooling system.
https://www.2carpros.com/forum/automotive_pictures/12900_t1_2.gif
Disconnect the lower radiator hose from the water outlet adapter.
https://www.2carpros.com/forum/automotive_pictures/12900_t2_1.gif
Remove the bolts, the water outlet adapter and thermostat.
Remove and discard the O-ring seal.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
BRANDYLYNNM
  • 2000 FORD TAURUS
  • 200,000 MILES
While replacing the thermostat in my 2000 Ford Taurus, the bolt broke off into the part that the housing hooks up to(not sure what it is) then while it was being drilled out the part that the bolt goes into snapped off of it. Not sure what the next step in getting this repaired would be, is that the intake manifold that goes into and how can this be fixed?
  • 108,133 POSTS
Yes, it is the intake. I don't know how big of a piece broke, so you may want to have a welder take a look at it. If it isn't repairable, then your only choice is to replace the intake.
