From the sound of it the problem is in the key
dealer is your only help for a new key ___
inside that plastic cover on the key you have a transponder
and that's what enable the security system
I would make sure I have nothing electronic or magnetic on or with the ignition key
(Mobil speed pass and so on...)
if you have an after market remote starter
same will happen too
also you can have it scanned as it has a self diagnostic system
and you can retrieve codes that will help pin pointing the issue
good luck
Wednesday, October 31st, 2018 AT 11:44 AM
(Merged)
