2000 Ford Taurus Tail Lights
RICKY12342682
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 187,000 MILES
I have a ford taurus 2000, I recently changed the break switch because my break light would not turn off, Now the issue that my tail lights are not working. Taurus does not have a fuze for the tail light I checked the bulb and looks fine. Turn signals and break lights turn on what should I do?
Do you
have the same problem?
Wednesday, June 2nd, 2010 AT 10:48 PM
Check and test the park relay and the multifunction switch
Thursday, June 3rd, 2010 AT 4:53 AM
RICKY12342682
I check the park relay and the multifunction switch still not a thing of light all wires are connected in no sight of loose connection.
Thursday, June 3rd, 2010 AT 2:25 PM
If the switch and relay tested good the running light circuit is open or shorted to ground after it leaves the switch
Thursday, June 3rd, 2010 AT 4:41 PM
RICKY12342682
Where do you find those grounds you speak about?
Thursday, June 3rd, 2010 AT 10:54 PM
Recommended Guides
