2000 Ford Taurus Over Heated
BADWIFEE
  • 2000 FORD TAURUS
  • 6 CYL
  • 90,000 MILES
Wife drove trough desert with windows up and AC on FULL BLAST.
Car overheated and was towed home. Upon inspection,
Car was refilled with water with no leaking found; No Water found in Oil.
Transmission (or) PowerSteering Fluid found on exhaust manifold near Powersteering Resiour
but doesn't seem to be leaking. Car does not seem to be getting GAS (I think).
Will turn over but NO Start! If head gasket was blown wouldnt water leak from
somewhere and be found in the oil pan. Is there a fuel pump reset switch?
Do you have recomendation of what to check
Do you
have the same problem?
Wednesday, June 3rd, 2009 AT 10:16 AM
BMRFIXIT
  • EXPERT
Fuel shut off switch is in the trunk
if over heated and the switch is OK
need to do a compression test
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, June 3rd, 2009 AT 7:53 PM
BADWIFEE
Thank You I was thinking along that line and will do as you say. Roughly hoe much does this tool cost at your local auto parts store?
Wednesday, June 3rd, 2009 AT 9:22 PM
BMRFIXIT
  • EXPERT
Its about $25
Thursday, June 4th, 2009 AT 5:04 AM
Recommended Guides
