2000 Ford Taurus oil or fluid like oil leaking from somewhe
CKFURRA
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 120,000 MILES
I'm trying to figure out where I could have a fluid leak, that looks like oil, coming from somewhere around the belt and pulley area. It drips down onto exhaust area below engine causing smoke to billow out from under the car. Any suggestion where it could be leaking from around that area before I start taking everything out? What to look for?
Do you
have the same problem?
Friday, January 15th, 2010 AT 1:40 PM
BMRFIXIT
  • EXPERT
Check oil pan and oil pan gasket
Saturday, January 16th, 2010 AT 5:48 AM
Recommended Guides
