2000 Ford Taurus leaking antifreeze bad
SCHMED72
  • 2000 FORD TAURUS
Engine Cooling problem
2000 Ford Taurus 6 cyl Front Wheel Drive 148000 miles
i have a bad leak under the right front part of the motor. It is so bad that it goes through about a half gallon in 50 miles. I can't tell where it is exactly leaking but I know it is not from the resevoir. Any ideas?
Do you
have the same problem?
Friday, October 9th, 2009 AT 3:45 PM
BMRFIXIT
  • EXPERT
Check heater core pipes
Friday, October 9th, 2009 AT 10:25 PM
Recommended Guides
