Hood Latch?
SANTORO5
  • 2005 FORD TAURUS
Does anyone know what the length of the small spring attached to the hood release cable is? Mine broke and my hood won't stay down so I'm just going to replace that spring but I'd like to know what the size approximately is.
Thank you!
Thursday, September 11th, 2014 AT 8:12 AM
HMAC300
  • 48,601 POSTS
No it' part of an assembly check with dealer they may have it.
Thursday, September 11th, 2014 AT 8:17 AM
SANTORO5
Yeah I called the dealer. They said I'd have to buy the whole assembly because they don't sell the parts individually. I'm definitely not spending 56$ for something that is just a broken spring.
Thursday, September 11th, 2014 AT 8:18 AM
HMAC300
  • 48,601 POSTS
Then to a hardware store and measure with latch closed then open that should put you close enough. Or get one from a junkyard.
Thursday, September 11th, 2014 AT 9:30 AM
SANTORO5
Went to a hardware store and bought a spring, put it in and it works fine! Thanks
Thursday, September 11th, 2014 AT 1:17 PM
MARTYGRAY
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 81,000 MILES
I am unable to open the hood of the ford taurus. Once Open I expect I should be able to repair or replace whatever needs attention but for now I need to know how to release the latch. The cable pull inside the car seems to work ( at least against a spring under the hood from the sound of it ) but I can't get beyond that point
Thursday, November 26th, 2020 AT 8:24 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Have somebody push down on hood while you pull cable.
MARTYGRAY
Had pushed and pulled on that hood several times with no luck. This time however, it finally popped open. I Was actually expecting other advice. Good to know I wasn't too far off base. You may have a new customer, will definitely let others know about this site. Thanks for the suggestion.
Thursday, November 26th, 2020 AT 8:25 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Your welcome glad it worked and cable not broken that is a different story. Can you make adjustment to get it right?
MARTYGRAY
After operating the latch release a few times everything seemed to be working freely, so put some penetrating oil on the working parts, cleaned up and put very light oil on the hood pistons. Worked things a few times more and expect I've got it taken care of although this may be something to watch out for in the future
ROME4129
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 127,000 MILES
Hello my issue is with my latch assembly it closes but latch will not lock hood in its place the cord is not broken just the lock park of this, it appears the spring is broken, this is whats I believe why the hood is not locking in place how can I replace this without damaging the cord of the latch assembly.
Thank you
Jay
BMRFIXIT
  • 19,053 POSTS
Need new hood latch its about $ 44 from the dealer
buy the new one 1st and before disconnecting the old one out
cable detach from the old one to fit on the new one not bad of a job you can do it
GREAT GM
  • 2000 FORD TAURUS
  • 6 CYL
  • 150,000 MILES
The hood latch will not lock the hood closed. The release in the car pulls out and back into place; however, when I press or slam the hood down the latch will not catch and hold. I tried to manually shut the latch by pressing down on the hook with a screwdriver. The latch moves downward but the locking mechanism will not activate.
  • 108,139 POSTS
Have you tried to lubericate it?
GREAT GM
Already tried to lubericate the latch with WD-40
GREAT GM
Thanks! All fixed. Detached part and replaced spring on the bottom of the latch.
  • 108,139 POSTS
Great! I'm glad you fixed it. Let us know if you have questions in the future.
JEFF43614
  • 8 POSTS
  • 2000 FORD TAURUS
  • 155,000 MILES
Hood won't stay latched. Tried WD40 like other websites suggested and that didn't work. Large tight spring is not broken as other sites suggested. While taking the assembly apart, I noticed a small spring that is 1-1/4" tall with a small hook on it (picture enclosed)sticking up from the body? Of the car. I noticed the hook on top was not hooked to anything but the closest thing was the cable. Two questions: 1) was this spring my initial problem? Because it wasn't attached to anything, was it not allowing another part to work properly and thus lock my hood? And 2) since it appears it was attached to the body of the car somehow, can it be replaced?
RIVERMIKERAT
  • 6,110 POSTS
It is probably the return spring for the release cable.
JEFF43614
  • 8 POSTS
Doesn't answer either question. Anyone one else?
CADIEMAN
  • 3,544 POSTS
These are parts of the hood latch. Youll need to replace the latch assy. Jeff
