2000 Ford Taurus
RUSSELLY
  • 2000 FORD TAURUS
Engine Mechanical problem
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic
Removed and replaced the upper intake manifold on my 2000 24v duratec.
Need the torque specs for the 8 bolts (5/16 or 8mm).
Some sources claim 84 in lbs (7 ft lbs). Haynes (very unreliable) has 18 ft lbs. Other show values in between.
If anyone has the RIGHT number, cast in stone, from on high, no-question-about-it, I hope you can share it.
Thanks, RY
Do you
have the same problem?
Friday, October 1st, 2010 AT 12:31 AM
WRENCHTECH
  • EXPERT
Here are the factory specs
71-106 inch lbs
Friday, October 1st, 2010 AT 5:47 AM
Recommended Guides
