1999 Ford Taurus heater core
JAZZERDO
  • 1999 FORD TAURUS
  • 6 CYL
  • 82,000 MILES
How do I take out the bad heater core and replace it?
Do you
have the same problem?
Tuesday, February 19th, 2008 AT 10:26 AM
BMRFIXIT
  • EXPERT
Its not an easy job
1-Drain coolant
2. Disconnect heater hose from heater core.
3. Remove instrument panel
4. Remove 4-screws retaining A/C electronic blend door actuator from heater/evaporator housing. Remove actuator. Remove mental cover, disengage spring from heater core cover and remove spring from lever.
5. Remove 3 heater core cover screws and cover
may I suggest a manual
Tuesday, February 19th, 2008 AT 11:27 AM
Recommended Guides
